[GRASS-dev] [GRASS GIS] #1651: Map display Query Vector tool fails
trac at osgeo.org
Sun Aug 26 03:22:32 PDT 2012
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: query, vector | Platform: Linux
Cpu: Unspecified |
Comment(by vincent):
Replying to [comment:1 neteler]:
> Can you please retry with a current 6.4.svn version?
Ok for db driver case.
But same contour map created against pg driver returns an error on
request.
Loading the map in the display, right-mouse to define Properties ->
Selection -> WHERE -> cast(level as decimal) % 10 = 0
There is no error on display, ie the sql filter works.
But when you want to query the map (display window : query raster/vector
map(s) tool), it fails, returning this error :
File "/usr/local/grass-6.4.3svn/etc/wxpython/mapdisp/mapwi
ndow.py", line 914, in MouseActions
self.OnLeftUp(event)
ndow.py", line 1120, in OnLeftUp
self.parent.Query(self.mouse['begin'][0],self.mouse['begin']
[1], layers)
File
"/usr/local/grass-6.4.3svn/etc/wxpython/mapdisp/frame.py",
line 681, in Query
self.QueryVector(east, north, qdist, posWindow, layers[0])
File
line 827, in QueryVector
qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId =
False)
File
line 880, in AddTmpVectorMapLayer
parg,pval = p.split('=')
ValueError
too many values to unpack
Ticket URL: <http://trac.osgeo.org/grass/ticket/1651#comment:2>
