[GRASS-dev] [GRASS GIS] #1615: Regression - v.transform fails to create a 3D map, crashes on Windows
trac at osgeo.org
Sun Aug 26 05:30:50 PDT 2012
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:9 hellik]:
> Replying to [comment:8 mmetz]:
> > Replying to [comment:7 mmetz]:
> > > Fixed in all branches (r52782-4). Please test.
> > There are more fixes in r52791-3. These should fix the previously
observed crashes and the coor mismatch, it was the by now usual suspect of
a still open database driver.
> tested here with osgeo4w-wingrass6.4.3svn r52917
> v.transform still crashes here; the coor mismatch remains, but the
output vector seems to be 3D.
| Anzahl Punkte: 1 Anzahl Flächen: 0
| Karte ist 3D: Yes
| Projektion: Lambert Conformal Conic
| N: 221154.04217658 S: 221154.04217658
| E: 635205.84734642 W: 635205.84734642
| B: 0 T: 0
Unfortunately, the z coordinate of the one single point created is zero, I
would call the output vector fake 3D.
Tested here on XP with the wingrass 6.4.svn standalone installer r52917,
should be the same like yours, but it works. No crash, no coor mismatch,
all 10 points have been transformed, and bottom and top make sense, i.e.
are identical to min and max in the h column.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1615#comment:10>
