[GRASS-dev] [GRASS GIS] #1615: Regression - v.transform fails to create a 3D map, crashes on Windows
GRASS GIS trac at osgeo.org
Sun Aug 26 08:06:33 PDT 2012
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.3
Component:  Vector       |     Version:  6.4.2
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mmetz):
 Replying to [comment:13 hellik]:
 > tested now several times in osgeo4w-wingrass6.4.3svn r52917 (heavy other
 work are in the background: arcgis, gimp, etc.): crash or no crash seems
 to be random; if no crash, no 3D output.
 > still memory issues?
 Could be. In your debug report, only two out of ten attribute table
 entries are copied, then the debug report ends. But then this is such a
 small vector, just a few KB, that memory issues are hard to imagine.
 Some testing suggestions:
 restart Windows, start GRASS and nothing else, then test
 v.random output=rm_a_map n=10 zmax=100.0 column="h double precision"
 v.transform input=rm_a_map output=rm_a_map3d table=rm_a_map
 columns=zshift:h
 v.info map=rm_a_map3d
 now restart Windows, first start all sorts of other apps, make them work
 long and hard, now start GRASS with the commands above.
 Ideally, do everything with DEBUG=4 and report the results.
 No further ideas from my side so far (GRASS is still not starting on my
 Windows 7 box).
 Thanks a lot for your efforts!
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1615#comment:14>
