[GRASS-dev] [GRASS GIS] #1615: Regression - v.transform fails to create a 3D map, crashes on Windows
trac at osgeo.org
Sun Aug 26 09:56:00 PDT 2012
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:14 mmetz]:
> Some testing suggestions:
> restart Windows, start GRASS and nothing else, then test
> v.random output=rm_a_map n=10 zmax=100.0 column="h double precision"
> v.transform input=rm_a_map output=rm_a_map3d table=rm_a_map
columns=zshift:h
> v.info map=rm_a_map3d
testing part 1: restarting windows, notepad++ (for storing debug info) and
GRASS as only two started software (norton firewall in the background).
v.random --verbose output=rm_a_map n=10 zmax=100.0 column=h double
precision
v.report map=rm_a_map at user1 option=coor
Zeige Typ/Name der Spalten der Datenbank des Layers 1:
cat|h|x|y|z
1|4.629658|635570.696127201|220671.590319529|0
2|83.669546|636487.166966765|216334.467604602|0
3|83.394879|640837.427900021|222324.945829646|0
4|32.062746|635209.967345195|225262.09295938|0
5|59.938353|633464.003418073|217668.935209204|0
6|0.018311|632945.341349529|215628.299813837|0
7|0.012207|632348.399304178|221032.91421247|0
8|56.599628|638098.544267098|222962.309640797|0
9|7.74865|639610.126041444|226608.096560564|0
10|74.4438|634732.505264443|219473.49467452|0
columns=zshift:h
v.transform crashes, debug=4-log as txt-file attached.
v.info-debug=4-log also in the txt-file.
| Layer: rm_a_map3d at user1
| Mapset: user1
| Datenbank: \grassdata
| Titel:
| Maßstab: 1:1
| Kartenformat: native
| Name des Erzeugers: myricaria
| Organisation:
| Quelldatum: Sun Aug 26 18:34:00 2012
| Typ der Karte: Vektor (Level: 1)
| Anzahl Punkte: 10 Anzahl Flächen: 0
| Anzahl Linien: 0 Anzahl Inseln: 0
| Anzhal Grenzen: 0 Anzahl faces: 0
| Anzahl Zentroid: 0 Anzahl Kerne: 0
| Karte ist 3D: Yes
| Anzahl der dblinks: 1
| Projektion: Lambert Conformal Conic
| N: 226608.09656056 S: 215628.29981384
| E: 640837.42790002 W: 632348.39930418
| B: 0.012207 T: 83.669546
| Digitalisierungs-Schwellwert: 0
| Kommentare:
v.report map=rm_a_map3d at user1 option=coor
ERROR: Kann die Vektorkarte <rm_a_map3d at user1> nicht auf Level 2 öffnen.
Versuchen Sie die Topologie mit v.build neu anzulegen.
cat|x|y|z
v.build map=rm_a_map3d at user1
Coor-Datei der Vektorkarte <rm_a_map3d at user1> ist größer als sie sein
sollte (384 Byte zuviel).
cat|x|y|z
1|635570.696127201|220671.590319529|4.629658
2|636487.166966765|216334.467604602|83.669546
3|640837.427900021|222324.945829646|83.394879
4|635209.967345195|225262.09295938|32.062746
5|633464.003418073|217668.935209204|59.938353
6|632945.341349529|215628.299813837|0.018311
7|632348.399304178|221032.91421247|0.012207
8|638098.544267098|222962.309640797|56.599628
9|639610.126041444|226608.096560564|7.74865
10|634732.505264443|219473.49467452|74.4438
(Sun Aug 26 18:38:52 2012) Befehl ausgeführt (1 sec)
so it seems the v.transform is now 3D, but still coor mismatch.
> now restart Windows, first start all sorts of other apps, make them work
long and hard, now start GRASS with the commands above.
...after next windows restart.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1615#comment:15>
