[GRASS-dev] [GRASS GIS] #151: make documentation be full text searchable: use sphinx
GRASS GIS trac at osgeo.org
Wed Aug 29 11:52:56 PDT 2012
 Reporter:  timmie       |       Owner:  epatton
     Type:  enhancement  |      Status:  assigned
 Priority:  major        |   Milestone:  7.0.0
Component:  Website      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [comment:33 neteler]:
 > > The output of the --interface-description switch has a well-defined
 format, so the relevant information can readily be extracted from the
 generated HTML file e.g. using a Python script based upon
 tools/g.html2man/html.py.
 > While well defined, it is much easier and not that invasive to directly
 render the
 > module parameters/flags descriptions in ReST.
 > > IMHO, it's preferable to cluttering up the build system with ReST-
 specific features.
 > A Makefile guru may well see that the current approach could be
 simplified
 > (rather than ditched).
 The current approach mirrors the mechanism used to generate the HTML
 files, which is significantly more involved than the mechanism used to
 generate the manual pages from the completed HTML files. If we can
 generate the ReST files directly from the completed HTML files (and
 there's no fundamental reason why we can't), it would simplify the build
 process somewhat.
 In r52956, I've modified the --html-description output to make it easier
 to parse (adding DIV tags around various sections) and added a script to
 generate ReST output from the completed HTML pages.
Ticket URL: <https://trac.osgeo.org/grass/ticket/151#comment:35>
