[GRASS-dev] Problem compiling ximgview in the latest grass_trunk
Thu Aug 30 19:22:30 PDT 2012
Pierre Roudier wrote:
> I still got the same problem - I'm happy to use the workaround and
> edit the Platform.make file by hand, but should I lodge a bug report
> in the tracker?
Please do.
Even though ximgview is redundant (the same functionality is available
via both wximgview and wximgview.py), we need raw access to Xlib for
reasons related to NVIZ.
