[GRASS-dev] Problem compiling ximgview in the latest grass_trunk
Pierre Roudier
pierre.roudier at gmail.com
Thu Aug 30 16:29:30 PDT 2012
Hi Glynn et al.,
I still got the same problem - I'm happy to use the workaround and
edit the Platform.make file by hand, but should I lodge a bug report
in the tracker?
Cheers,
Pierre
2012/7/14 Pierre Roudier <pierre.roudier at gmail.com>:
> Thanks heaps for your help Glynn, it worked.
> For reference, here's the workaround I used:
> roudierp at mangatainoka:/usr/local/src/grass_trunk$ more
> include/Make/Platform.make | grep -n XLIB
> 86:XLIBPATH = -L/usr/bin
> Cheers,
> Pierre
> 2012/7/14 Glynn Clements <glynn at gclements.plus.com>:
>> Pierre Roudier wrote:
>>> Is there an easy work-around this?
>> Provided that the configure script completes, you can edit
>> include/Make/Platform.make by hand. The relevant variables are
>> XLIBPATH and XLIB.
> Scientist
> Landcare Research, New Zealand
Scientist
