[GRASS-dev] Standalone GUI modules: Makefile
Martin Landa landa.martin at gmail.com
Wed Dec 5 04:45:08 PST 2012
2012/12/5 Glynn Clements <glynn at gclements.plus.com>:
> The attached version works for me with make 3.82. I don't have 3.81 to
> test with, but I would have thought that there would be some
> formulation which results in g.gui.%.tmp.html being preferred over
> %.tmp.html.
unfortunately it's not working with make 3.81.
> If there isn't, the common definitions (htmldesc, IMGSRC, IMGDST) and
> pattern rules ($(HTMLDIR)/%.png, $(HTMLDIR)/%.jpg) should be moved to
> a separate file which can then be included from both Html.make and
> GuiScript.make.
seems to be an option. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
