Vaclav Petras wrote: > Why the directory layout in source codes differs form the layout in > dist directory? Originally, the only Python code was the grass.script library (which was just called "grass"). ctypes, temporal and pygrass were added later. -- Glynn Clements <glynn at gclements.plus.com>
