[GRASS-dev] what do you think about re-organized the /lib/python files?
Pietro
peter.zamb at gmail.com
Thu Dec 6 02:11:59 PST 2012
On Thu, Dec 6, 2012 at 7:53 AM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Vaclav Petras wrote:
>> Why the directory layout in source codes differs form the layout in
>> dist directory?
> Originally, the only Python code was the grass.script library (which
> was just called "grass"). ctypes, temporal and pygrass were added
> later.
But do you think that there are some good reasons that suggest to not
touch the current layout?
Because, as Vaclav, I would prefer a consistent layout between source
and dist directories.
Piero
