[GRASS-dev] GRASS7 ImageryLib
Markus Metz
markus.metz.giswork at gmail.com
Sun Dec 9 09:24:46 PST 2012
On Sun, Dec 9, 2012 at 5:30 AM, Mohammed Rashad
<mohammedrashadkm at gmail.com> wrote:
> On Sun, Dec 9, 2012 at 1:51 AM, Markus Metz <markus.metz.giswork at gmail.com>
> wrote:
>> [answering here because I have worked on some of the affected modules]
>> On Wed, Dec 5, 2012 at 6:16 PM, Mohammed Rashad
>> > On Fri, Nov 30, 2012 at 7:46 PM, Markus Neteler <neteler at osgeo.org>
>> > wrote:
>> >> On Fri, Nov 30, 2012 at 5:26 AM, Mohammed Rashad
>> >> > All,
>> >> > I found these here[1] and says many things which needed help. So I
>> >> > thought
>> >> > to give a try in order
>> >> > 1. Imagery Library needs fundamental clean up (the library is not
>> >> > maintained
>> >> > from GRASS 5)
>> >> > Anyone can elaborate on this line?
>> >> Fully agreed.
>> >> It might be sensible to merge the various image libraries:
>> >> GRASS 6/7:
>> >> * lib/imagery/: standard lib, in use (i.* except for i.points3,
>> >> i.rectify3, see below)
>> >> * imagery/i.ortho.photo/libes/: standard lib, in use (i.ortho.photo,
>> >> photo.*)
>> > i.points3 and i.rectify3 doesnt uses standard lib. So adding API style
>> > code
>> > which can be used by i.point3 and i.rectify3 is what you are saying. Am
>> > I
>> > correct?
>> I guess so, but I would suggest to move the libs needed by i.points3
>> and i.rectify3 to a separate GRASS lib, probably ortholib
>> > i.ortho.photo uses i.ortho.photo/libes right?
>> No, it uses (will use) ortholib, currently i.ortho.photo/lib, but I am
>> busy porting it and related modules to trunk.
>> > so merging both libs will provide an API which any grass imagery module
>> > can
>> > share right?
>> I would suggest to separate standard imagery lib and
>> orthorectification, because these two use substantially different
>> algorithms. The ortholib depends on imager lib.
> i.ortho.photo is under progress right? . So moving imager to a lib called
> ortholib under imagery like imagery/ortholib or as grass_trunk/ortholib is
> need to be done. right?
I would prefer lib/ortho.
> So If I start moving code around will it affect the current work on i.ortho
> and friends?
Yes. I have already modified imagery/i.ortho.photo/lib in trunk but
not yet submitted. It's working now for me in trunk, as well as
i.photo.rectify. Please don't modify imagery/i.ortho.photo/lib before
I have submitted my changes.
>> >> GRASS 5 (! only) image3 lib:
>> >> * libes/image3/: never finished improvement which integrated the
>> >> standard lib and the ortho lib. Seems to provide also ortho
>> >> rectification for satellite data (i.points3, i.rectify3)
>> >> GRASS 5/6 image proc commands:
>> >> * merge of i.points, i.vpoints, i.points3 (see above)
>> >> * merge of i.rectify and i.rectify3 (see above)
>> >> Overall
>> >> * add other warping methods (maybe lanczos or thin splines from GDAL?)
>> > This part is not clear to me at all
>> Lanczos is already available.
>> What could be gained by adding thin splines to the existing bilinear,
>> bicubic, bspline, lanczos methods?
> This question is not clear for me
These interpolation methods are used by i.rectify, i.photo.rectify,
r.proj, r.resamp.interp. Adding thin splines might be a valuable
addition, but it could also cause confusion (too many methods to
choose from). These methods are in lib/raster/interp.c.
Markus M
>> >> However, the library cleanup in GRASS 7 would be essential.
>> >> > 2. Reimplement groups to be generic element (in GIS Library)
>> >> > I guess i.group module should be g.group which can groups both
>> >> > raster/vector
>> >> > maps
>> >> > Is that correct?
>> >> Correct I don't know, maybe subject to discussion.
>> > Anyone have any comments ?
>> >> Best
>> >> Markus
>> > Regards,
>> > Rashad
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
> Rashad
