[GRASS-dev] wxGUI Raster Digitizer
Mohammed Rashad mohammedrashadkm at gmail.com
Thu Dec 20 03:35:43 PST 2012
Hi Markus,
     From your screenshot What I understand is you loaded a raster map but
did not created or selected the map to be saved. Output map seems to be
empy. I had updated svn for check if map is available. Now wx.rdigit shows
error message if no map is selected
Also All your Observations are considered and module is modified accordingly
Please update source and try again.
PS: There is a feature not implemented in it which asks for category id and
num for each digitized object created. I will implement it after current
testing. Because there are some discussion regarding no need for a
digitizer since the same can be acheived from v.digit and v.to.rast
On Thu, Dec 20, 2012 at 4:04 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Dec 20, 2012 at 11:18 AM, Mohammed Rashad
> <mohammedrashadkm at gmail.com> wrote:
> > from grass-addons/grass7/gui/wxpython/wx.rdigit
> > python frame.py
> Ok, it starts. I can digitize, nice. See screenshot.
> Some observations:
> *  the right mouse button does not stop the digitizer as I would expect
> * The Quit eats the digitized lines rather than opening the save
>   dialog (if saving still needed) and quitting.
> * Perhaps have the digitizing tools always "on" and remove the button
>   for switching them on?
> Best
> Markus
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121220/faa4e507/attachment.html>
