[GRASS-dev] Updating colorrules.py
Mohammed Rashad
mohammedrashadkm at gmail.com
Sat Dec 22 06:59:45 PST 2012
On Sat, Dec 22, 2012 at 5:46 PM, Anna Kratochvílová
<kratochanna at gmail.com>wrote:
> > On Thu, Dec 20, 2012 at 11:45 AM, Mohammed Rashad
> > <mohammedrashadkm at gmail.com> wrote:
> >> updated the patch. PFA
> I've tested it on Ubuntu 12.04 (running in virtaul machine) with
> wxPython 2.8.12.1 and there are some bugs. I've attached a screenshot.
> As you can see I have a problem with strange background of
> checkboxes. I tried wxPython demo and this problem is there too so
> probably we cannot do much about it. Do you have the same problem or
> it's just me?
Same happens for me. But sometimes only !. see the screenshot
> Then, when you change the color table (above the rules, there is 'Load
> color table'; e.g. from rainbow to aspect) the original numbers in the
> list ctrl are still there below the new ones.
> I also had sometimes problems to uncheck the items but I am not sure
> under which conditions (maybe after changing colortable).
Fixed in the new version
> In the beginning when there is no map loaded there are the two
> original wx.TextCtrl widgtes
> Have you tried to avoid the dialog for setting values? Ideally, user
> could edit the rule's value directly in the listctrl and click (or
double click) on the color would launch the wx color dialog.
> I sincerly tried a lot for this but ultimatelistctrl has no such provision
or there is a bug in my version
> I think that this solution with ultimatelistctrl looks much better
> than the original, however we must first make it work properly.
> Anna
PFA colorrules.py. If things are looking good. I will provide a patch
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121222/1938b8c6/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121222/1938b8c6/attachment-0001.obj>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121222/1938b8c6/attachment-0001.png>
