[GRASS-dev] [GRASS GIS] #1840: r.drain manual example not working
GRASS GIS trac at osgeo.org
Mon Dec 24 05:56:37 PST 2012
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.3
Component:  Raster       |     Version:  svn-releasebranch64
 Keywords:  r.drain      |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by rashadkm):
 with the attached diff and drain.c it produces correct output from
 r.drain. I had tested diffrent start location and it worked
 Only problem is output map is always of type CELL. Will it be  a problem?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1840#comment:1>
