[GRASS-dev] [GRASS GIS] #1840: r.drain manual example not working
trac at osgeo.org
Thu Dec 27 08:10:37 PST 2012
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Raster | Version: svn-releasebranch64
Keywords: r.drain | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:1 rashadkm]:
> with the attached diff and drain.c it produces correct output from
r.drain. I had tested diffrent start location and it worked
> Only problem is output map is always of type CELL. Will it be a
problem?
Yes, it will be a problem, because the examples in the manual of r.drain
are based on a DEM, in which case the code is correct and the example is
wrong, the path should stop as soon as a border is reached or any neighbor
cell is NULL.
I have updated r.cost/r.walk/r.drain in r54417-9. r.drain can now read
GRASS standard directions, e.g. flow directions from r.watershed
(multiplied with 45 in order to get degrees CCW from East) in addition to
movement directions from r.cost/r.walk. The examples in the manual of
r.drain are fixed.
What remains to be tested and fixed is input from r.cost/r.walk where the
path reaches a border.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1840#comment:2>
