[GRASS-dev] List of new features in GRASS 7: please update
Paulo van Breugel p.vanbreugel at gmail.com
Fri Dec 28 05:46:28 PST 2012
Nice work Markus!
I am not very good in catchy intro words, but I would mention the number
of new modules (44+ vector, grass and image modules + general, GUI, etc
modules) and some key improvements / enhancements of existing modules
(like the very significant speed improvements in vector handling)?
I guess the links are made with some kind of alias? Would it be possible
to not show the 'G7:' as part of all links?
One question about bash the scripts. it is mentioned that all bash
scrips are converted to Python. Perhaps obvious, but these concerns the
scripts that are part of the GRASS installation. One can still use
external bash scripts (and hopefully that will remain the case). For
example, most scripts available in the grass 6 add-on repository can be
used in grass 7, albeit sometimes some adaptations are needed because of
syntax changes)
Cheers,
Paulo
On 12/27/2012 04:39 PM, Markus Neteler wrote:
> On Fri, Dec 7, 2012 at 1:55 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> Hi all,
>> a lot has happened in the past months in GRASS 7 with tons of
>> improvements: To better showcase the improvements, please
>> help to update
>> http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
>> Also "xyz module www times faster than GRASS 6" is a relevant
>> information. Certainly not every new flag should be documented
>> on that page but the major improvements need to be listed.
>> Please help (editing possible with OSGeo ID),
> I have added links to the respective manual pages (in trac
> much uglier than in Mediawiki but perhaps useful enough) and
> made some cleanup.
> Some catchy intro words would be cool!
> Please edit the page, it's a wiki!
> Markus
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121228/58c86d02/attachment-0001.html>
