[GRASS-dev] [GRASS GIS] #1801: r3.in.ascii fails in GRASS6.4.3
    trac at osgeo.org
    Sat Dec 29 21:11:43 PST 2012
 Reporter:  helena                        |       Owner:  grass-dev@…
     Type:  defect                        |      Status:  new
 Priority:  critical                      |   Milestone:  6.4.3
Component:  Raster3D                      |     Version:  svn-releasebranch64
 Keywords:  r3.in.ascii, raster3d import  |    Platform:  MacOSX
      Cpu:  OSX/Intel                     |
Comment(by helena):
 I found that r3.in.ascii fails when there is nulls exported as * in the
 ascii file
 GRASS 6.4.3svn (nc_spm_05):~/grassdata/indata/test3d > r3.in.ascii
 hatelevnull3d.asci out=test3d_importfpnull
 Loading data ... (484x654x10)
 ERROR: asciiToG3d: read failed
 if I replace * with 0 it reads the file OK
 hatelev_test3d.asci out=test3d_importfp0
 r3.in.ascii complete.
 but as mentioned above, the initialization of the parameters has bugs, for
 example, if I try to define null as *
 (which is the default for r3.out.ascii) I get error
 hatelevnull3d.asci out=test3d_importfpnull nv=* --o
 ERROR: getParams: NULL-value value invalid
 (nv="*" does not help)
 perhaps because it expects number instead of string in main.c ?
     param.nv = G_define_option();
     param.nv->key = "nv";
     param.nv->type = TYPE_STRING;
     param.nv->required = NO;
     param.nv->multiple = NO;
     param.nv->answer = "none";
     param.nv->description =
         _("String representing NULL value data cell (use 'none' if no such
 value)");
 static void
 getParams(char **input, char **output, int *convertNull, double
 *nullValue)
     *input = param.input->answer;
     *output = param.output->answer;
     *convertNull = (strcmp(param.nv->answer, "none") != 0);
     if (*convertNull)
         if (sscanf(param.nv->answer, "%lf", nullValue) != 1)
             fatalError("getParams: NULL-value value invalid");
     G_debug(3, "getParams: input: %s, output: %s", *input, *output);
 The default,default issue seems to be indeed in g3dparam.c -for example,
 I think the answer should be float instead of default here:
  param->type->answer = "default";
     param->type->options = "default,double,float";
     param->type->description = _("Data type used in the output file");
 It is supposed to get value described in G3D Defaults, but it does not.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1801#comment:4>
