[GRASS-dev] Indented comments in Makefile not compatible withmake-3.82
Daniel Macks
dmacks at netspace.org
Sun Dec 30 02:58:25 PST 2012
On Fri, 1 Jun 2012 08:28:02 +0100, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Daniel Macks wrote:
> > The problem appears to be just after the above "sed" command, where
> > macosx/modbuild/Makefile has:
> > > @# until I figure out how to get sed to replace with
> multiple lines in a
> > @# makefile, GRASS_APP required for modbuild, ie no default
> to /Applications
> > @#-e 's#^GISBASE.*#ifdef GRASS_APP\
> > @#GISBASE = $$(GRASS_APP)/Contents/MacOS\
> > @#else\
> > @#GISBASE = $(INST_DIR_MACOSX)\
> > @#endif#g'
> > @# html.make needs a little change
> It's the leading @ which causes the problem; a # only begins a comment
> when it appears at the beginning of a word:
> Removing the leading '@' from each continuation line should suffice,
> i.e.:
> @# until I figure out how to get sed to replace with multiple lines in a
> @# makefile, GRASS_APP required for modbuild, ie no default to /Applications
> #else\
> #endif#g'
Ping? 6 months, several releases, and this is still broken.
dan
Daniel Macks
