[GRASS-dev] temporal: gettext warnings
Sören Gebbert soerengebbert at googlemail.com
Mon Feb 6 08:44:00 EST 2012
using named convection[1] suggested by Martin is the correct solution?
http://trac.osgeo.org/grass/changeset/50514#file2
Best regards
Soeren
2012/1/30 Glynn Clements <glynn at gclements.plus.com>:
> Martin Landa wrote:
>> ../lib/python/temporal/datetime_math.py:227: warning: 'msgid' format
>> string with unnamed arguments cannot be properly localized:
>> The translator cannot reorder the arguments.
>> >> They could be fixed by splitting the message [1] ...
>> > [1] is the wrong thing to do ...
>> I am not sure if we are speaking about same thing.
> I'm talking about "splitting the message".
> IIUC, the issue relates to strings with more than one substitution. If
> the substitutions are matched with parameters by position (i.e. the
> first substitution uses the first parameter, etc), the translated
> string cannot have the parameters in a different order, even if that
> would be appropriate for a particular language.
> Splitting the message (so that each translated string contains a
> single substitution) might eliminate the warnings (I don't know
> whether it does, but I assumed that was the idea behind the "splitting
> the message" suggestion), but it won't do anything about the issue
> which caused the warning.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
