[GRASS-dev] Re: [GRASS GIS] #1568: 'make install' results in an installation dependent upon temporary build directories
GRASS GIS trac at osgeo.org
Wed Feb 8 01:42:45 EST 2012
directories
 Reporter:  helsene       |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  7.0.0
Component:  Installation  |     Version:  svn-trunk
 Keywords:                |    Platform:  Linux
      Cpu:  x86-64        |
Comment(by helsene):
 I've tried the README.debian instructions, they require some extra
 tinkering to get them going. Installing per the instructions requires
 'tcl' >=8.5, the dependency check fails even when 'tcl8.5-dev' is
 installed as the 'tcl' package either refers to 8.4 or is not installed.
 'tcl' needs to be pulled from wheezy for the README.debian instructions to
 proceed; but that's a separate issue.
 The 'debuild -i -uc -us -b' step in README.debian fails when it tries to
 run 'mkdir -p /usr/lib/bin' of all things.
 /usr/bin/make real-install
 make[2]: Entering directory `/home/helsene/src/g7_trunk'
 mkdir -p -m 755 /home/helsene/src/g7_trunk/debian/tmp/usr/lib/grass70
 mkdir -p -m 755 /usr/lib/bin
 mkdir: cannot create directory `/usr/lib/bin': Permission denied
 make[2]: *** [/usr/lib/bin] Error 1
 make[2]: Leaving directory `/home/helsene/src/g7_trunk'
 make[1]: *** [install] Error 2
 make[1]: Leaving directory `/home/helsene/src/g7_trunk'
 make: *** [install] Error 2
 dpkg-buildpackage: error: fakeroot debian/rules binary gave error exit
 status 2
 debuild: fatal error at line 1325:
 dpkg-buildpackage -rfakeroot -D -us -uc -i -b failed
 So far, two methods of compiling 7.0 for a multi-user Debian Squeeze
 install are not working with the given instructions. This 'debuild' error
 should probably be split into its own ticket depending on where the error
 lies ('make real-install' or the debian packaging git repo's configs). I
 don't know enough about the install scripts to judge that.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1568#comment:2>
