[GRASS-dev] Re: [GRASS-user] how to import NetCDF data??
Michael Barton
Michael.Barton at asu.edu
Wed Feb 8 02:01:29 EST 2012
Thanks much Hamish
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 7, 2012, at 10:39 PM, Hamish wrote:
> Michael wrote:
>> We had the same errors with a couple
>> of files. We sent Tom the simplest and smallest of them.
>> Once we figure out what is happening we can let everyone
>> know. It would probably be good to begin a WIKI page on this
>> once we have some info.
> there already is one: (albeit a bit empty)
> http://grass.osgeo.org/wiki/NetCDF
> see also:
> http://grass.osgeo.org/wiki/GRASS_and_GMT
> and the gdal_translate trick to extract the data layer into a geotiff,
> then import the geotiff into GRASS. (probably a direct import is
> possible, but the geotiff makes problems easier to understand)
> that method is explained here:
> http://grass.osgeo.org/wiki/MODIS#Method_1
> also in the above link is instructions for applying georef to the geotiff
> using gdal_translate as GDAL wasn't doing so, which is I think the same
> problem you'll be seeing.
> you get the 'illegal latitude for north' error because it has no georef
> (as far as gdal is reporting) and so falls back to 1 row per pixel. If
> the image is more than 90 pixels high that exceeds 90 degrees N and is
> illegal for a lat/lon location. You can override that in recent versions
> of GRASS with the r.in.gdal -l flag, but then Must use r.region directly
> after import to set the bounds to what they should be.
> Helena wrote:
>>> If there are still problems and if we can identify what needs to be
>>> developed to make working with netCDF in GRASS more robust perhaps
>>> this would be a good project for Google summer code
>>> (hopefully OSGeo is participating this tear again)
> hopefully :)
> anyway I think if there are georef problems they probably need to be
> addressed at the GDAL side of things, not in GRASS per se.
> Kirk wrote:
>>>> I had to import a bunch of SSURGO NetCDF data not too long ago
>>>> Michael (I was going back and forth with GRASS and MATLAB).
> any reason not to use r.in.mat, r.out.mat for that? i.e. any short-
> comings in those tools which should be addressed?
> regards,
> Hamish
