[GRASS-dev] GRASS Web site: compilation errors for G7
Markus Neteler
neteler at osgeo.org
Tue Feb 14 14:46:12 EST 2012
I fixed most on grass.osgeo.org to get the programmer's manual back (done)
and the binaries (almost done).
These ones I cannot fix:
Started compilation: Tue Feb 14 11:35:21 PST 2012
Errors in:
/home/neteler/grass7_svn_head_bin_snapshot/trunk/gui/wxpython
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Tue Feb 14 11:41:43 PST 2012
make: *** [default] Error 1
GRASS 70 compilation done
make real-bindist
make[1]: Entering directory `/home/neteler/grass7_svn_head_bin_snapshot/trunk'
tar cCBf /home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-unknown-linux-gnu
- AUTHORS COPYING CHANGES REQUIREMENTS.html GPL.TXT contributors.csv
contributors_extra.csv translators.csv grass70.tmp bin docs driver etc
fonts include lib man scripts locale | gzip -fc >
grass-7.0.svn-x86_64-unknown-linux-gnu-14_02_2012.tar.gz
tar: man: Cannot stat: No such file or directory
tar: Exiting with failure status due to previous errors
* gui/wxpython: compiles at 2nd attempt (known issue)
* man: Indeed, also in my local compilation I don't have a man/ directory,
to be removed from the tar command?
Markus
