[GRASS-dev] GRASS Web site: compilation errors for G7
Markus Neteler
neteler at osgeo.org
Wed Feb 15 03:50:44 EST 2012
On Wed, Feb 15, 2012 at 5:08 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> * man: Indeed, also in my local compilation I don't have a man/ directory,
>> to be removed from the tar command?
> The manual pagers were moved from $GISBASE/man to $GISBASE/docs/man in
> r49908.
Ok, main Makefile updated.
> FWIW, I suggest simply tar'ing the entire dist.<arch> directory rather
> than specific subdirectories. Currently, "make bindist" ignores the
> bwidget, demolocation and tools subdirectories. The lack of the last
> two mean that you won't be able to build GRASS components against a
> version installed from the bindist tarball.
I have updated for now include/Make/Install.make with the missing directories
and removed man/ also there.
Markus
