[GRASS-dev] GRASS Web site: compilation errors for G7
Hamish
hamish_b at yahoo.com
Wed Feb 15 14:42:14 EST 2012
Markus Neteler wrote:
>>> * man: Indeed, also in my local compilation I don't have a man/
>>> directory, to be removed from the tar command?
Glynn:
> > The manual pagers were moved from $GISBASE/man to $GISBASE/docs/man in
> > r49908.
> Ok, main Makefile updated.
sorry for the trouble, but I've just discovered that the man pages need
to go back into $GISBASE because of the way that `manpath` works.
it searches $PATH and for each path dir, if ../man/ exists it is added
to the manpath search list. Adding a symlink back there works, but seems
unnecessarily redundant.
GRASS65> manpath -d
path directory /usr/local/src/grass/svn/grass65/dist.i686-pc-linux-gnu/bin is not in the config file
but does have a ../man or man subdirectory
adding /usr/local/src/grass/svn/grass65/dist.i686-pc-linux-gnu/man to manpath
path directory /usr/local/src/grass/svn/grass65/dist.i686-pc-linux-gnu/scripts is not in the config file
/usr/local/src/grass/svn/grass65/dist.i686-pc-linux-gnu/man is already in the manpath
Hamish
