[GRASS-dev] GRASS and Paraview
Sören Gebbert
soerengebbert at googlemail.com
Wed Feb 15 13:32:19 EST 2012
Hi Michael,
2012/2/15 Michael Barton <Michael.Barton at asu.edu>:
> Soren,
> If I get bold enough to try this, do I need to have source trees of both GRASS and VTK? And if so, do I need to have VTK compiled? I'm using a binary of Paraview but don't have VTK independent of that (AFAIK).
I did not tested it with pre-compiled ParaView/VTK binaries ... but it
should work in theory. You need to make sure that there are VTK shared
libraries and that they are in your LD_LIBRARY_PATH and so the Python
bindings which must be in your PYTHONPATH variable.
But you will need cmake for configuration and a C++ compiler (only
tested with GNU compiler collection C++ compiler). I think there is no
way around the compilation HowTo.
> Also, do I need to put this anywhere in particular or will make install do it for me?
Make install should do the job, as /usr/local is the default
installation location which should be automatically in your path on a
Linux machine.
Best regards
Sören
> Thanks
> Michael
> On Feb 14, 2012, at 1:17 PM, Sören Gebbert wrote:
>> Hi,
>> 2012/2/14 Michael Barton <Michael.Barton at asu.edu>:
>>> Thanks Markus,
>>> But I don't quite understand how the bridge works. Do you run it from GRASS or ParaView, both or neither (i.e., from the terminal outside either program)?
>> The vtk-grass-bridge is a C++ library and must be compiled. I did not
>> test the compilation on Windows or Mac,
>> but it should work ..... in theory. The library depends on VTK[1],
>> cmake[2] and of course on GRASS GIS 7.
>> A detailed compilation guide is available here:
>> http://code.google.com/p/vtk-grass-bridge/wiki/HowToCompile
>> Once compiled, the C++ classes can be used together with VTK classes
>> in GRASS GIS Python modules. Hence, all the shiny data processing
>> algorithms available in ParaView can be used directly with GRASS GIS
>> raster, vector and raster3d.
>> Have a look at the Python examples[3, 4, 5, 6]. Since these modules
>> are regular GRASS "programs" they must be executed in a grass7 shell.
>> [1] http://www.vtk.org/
>> [2] http://www.cmake.org/
>> [3] http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Python/r3.gauss.smooth.py
>> [4] http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Python/v.sample.rast.py
>> [5] http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Python/r3.out.vtk2.py
>> [6] http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Python/
>> Best regards
>> Soeren
>>> Also, I assume it must be compiled. Do you (or someone) know if it has been compiled for Windows and Mac as well as Linux?
>>> Cheers
>>> Michael
>>> _____________________
>>> C. Michael Barton
>>> Visiting Scientist, Integrated Science Program
>>> National Center for Atmospheric Research &
>>> University Consortium for Atmospheric Research
>>> 303-497-2889 (voice)
>>> Director, Center for Social Dynamics & Complexity
>>> Professor of Anthropology, School of Human Evolution & Social Change
>>> Arizona State University
>>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>>> On Feb 14, 2012, at 11:21 AM, Markus Neteler wrote:
>>>> On Tue, Feb 14, 2012 at 7:13 PM, Michael Barton <michael.barton at asu.edu> wrote:
>>>>> GRASS has r.out.vtk, v.out.vtk, and r3.out.vtk to export GRASS data to
>>>>> Paraview files.
>>>>> But how can I read Paraview files back into GRASS?
>>>> Please see
>>>> http://grass.osgeo.org/wiki/GRASS_and_VTK
>>>> -> Import of VTK data into GRASS
>>>> Markus
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> C. Michael Barton
> University Corporation for Atmospheric Research
