[GRASS-dev] adding spacetime datasets to element list
Michael Barton Michael.Barton at asu.edu
Thu Feb 16 18:34:49 EST 2012
The GUI gets its list from g.list, so nothing needs to be done there. A couple things can be crossed off the list at least.
Michael
On Feb 16, 2012, at 4:22 PM, Sören Gebbert wrote:
> Hi Michael,
> this is a complex task. I will try to sketch a road map:
> 1.) Standard options for the new space time datasets must be specified
> in "lib/gis/parser_standard_options.c", as identifier the
> abbreviations of space time raster, vector and raster3d datasets
> should be used: stds, strds, stvds and str3ds:
> 1.1) G_OPT_STDS_INPUT and G_OPT_STDS_INPUTS  to specify options with
> strds, stvds and str3ds input(s), since several modules can handle
> different types of inputs. gisprompt = "old,stds,stds", key="input" or
> "inputs", key_desc = "name"
> 1.2) G_OPT_STRDS_INPUT, G_OPT_STRDS_INPUTS and G_OPT_STRDS_OUTPUT for
> space time raster dataset input(s) and output. gisprompt =
> "old,strds,strds" and "new,strds,strds", key="input" or "inputs" or
> "output", key_descr = "name"
> 1.3) The same scheme for space time vector and raster3d datasets
> 1.4) G_OPT_MAP_INPUT and G_OPT_MAP_INPUTS for modules which can handle
> raster, vector and raster3d maps. gisprompt="old,map,map", key = "map"
> and "maps", key_descr = "name"
> 1.5) G_OPT_STDS_TYPE options="strds,stvds,str3ds", answer="strds" to
> select a space time dataset type
> 1.6) G_OPT_MAP_TYPE  options="rast,vect,rast3d", answer="rast" to
> select a map type
> 1.7) All temporal modules must be updated to use the standard options
> 1.8) The WPS parser XML generator must be updated
> 2.) GUI -> well, i do not know much about the GUI
> 2.1) I don't know if the GUI XML description generator needs to be modified?
> 2.1) t.list should be used to list registered space time datasets in the GUI
> 2.2) In case of G_OPT_STDS_INPUT(S) the gui have to use t.list to get
> all space time datasets in the temporal database -> 6 calls:
> strds,stvds and str3ds for absolute and relative time, colored or
> marked by type
> 2.3) In case of G_OPT_MAP_INPUT(S) all available raster, vector and
> raster3d maps should be listed, colored or marked by type
> Anything more to do?
> Until this is implemented i would suggest to not use the GUI in case
> of temporal GIS framework modules. :)
> Best regards
> Soeren
> 2012/2/16 Michael Barton <Michael.Barton at asu.edu>:
>> At some point, we need to get the new space/time data sets, that organize
>> the temporal GIS features Sören is building, into the GRASS element_list.
>> This is needed so that these can be managed by g.list, etc and so that these
>> data sets can appear in a pull-down list in the GUI. I'm not sure what is
>> involved in doing this.
>> Michael
>> _____________________
>> C. Michael Barton
>> Visiting Scientist, Integrated Science Program
>> National Center for Atmospheric Research &
>> University Corporation for Atmospheric Research
>> 303-497-2889 (voice)
>> Director, Center for Social Dynamics & Complexity
>> Professor of Anthropology, School of Human Evolution & Social Change
>> Arizona State University
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
C. Michael Barton
