[GRASS-dev] Re: OSGeo4W-GRASS7: liblas support?
Helmut Kudrnovsky hellik at web.de
Fri Feb 17 07:25:11 EST 2012
Hi Markus,
>Would it be possible to activate that?
in principle yes, it should work (tested a little bit locally).
AFAIK liblas needs the osgeo4w-package 'proj-vdatm: proj4 vertical datum
shift files" which are
(compressed) about ~50 mb. within the osgeo4w-framework this shouldn't be a
issue.
by activating liblas-support the size of wingrass-standalone installer would
increase upt to ~100mb.
all the best
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/OSGeo4W-GRASS7-liblas-support-tp4479794p4479866.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
