[GRASS-dev] Re: OSGeo4W-GRASS7: liblas support?
Markus Neteler
neteler at osgeo.org
Fri Feb 17 07:45:58 EST 2012
On Fri, Feb 17, 2012 at 1:25 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Hi Markus,
>>Would it be possible to activate that?
> in principle yes, it should work (tested a little bit locally).
> AFAIK liblas needs the osgeo4w-package 'proj-vdatm: proj4 vertical datum
> shift files" which are
> (compressed) about ~50 mb. within the osgeo4w-framework this shouldn't be a
> issue.
This sounds good since it should be kind of modular.
> by activating liblas-support the size of wingrass-standalone installer would
> increase upt to ~100mb.
Well, too big for the standalone installer...
thanks
Markus
