[GRASS-dev] Re: OSGeo4W-GRASS7: liblas support?
Markus Metz
markus.metz.giswork at googlemail.com
Fri Feb 17 08:13:49 EST 2012
On Fri, Feb 17, 2012 at 1:45 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Feb 17, 2012 at 1:25 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
>> Hi Markus,
>>>Would it be possible to activate that?
>> in principle yes, it should work (tested a little bit locally).
>> AFAIK liblas needs the osgeo4w-package 'proj-vdatm: proj4 vertical datum
>> shift files" which are
>> (compressed) about ~50 mb. within the osgeo4w-framework this shouldn't be a
>> issue.
> This sounds good since it should be kind of modular.
>> by activating liblas-support the size of wingrass-standalone installer would
>> increase upt to ~100mb.
Even worse, liblas pulls in the Oracle client library, a monster of
~128 MB, i.e. the installer size would be closer to 200 MB than 100
MB...
Markus M
> Well, too big for the standalone installer...
> thanks
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
