[GRASS-dev] why doesn't g.region launch gui?
Michael Barton
Michael.Barton at asu.edu
Sat Feb 25 10:45:01 EST 2012
On Feb 25, 2012, at 1:10 AM, Maris Nartiss wrote:
> Hello Michael,
> in GRASS 7 it's not a bug, it's a feature! [1]
You mean this with a considerable dose of sarcasm, right?
> If it's happening also in 6.4, then it's a result of backporting and
> should be treated as a serious regression and thus should be fixed
> ASAP.
Yes. It's not fatal, but it is confusing to users.
Michael
> Maris.
> 1. http://osgeo-org.1560.n6.nabble.com/wxGUI-new-packages-layout-tp3992790p3992803.html
> 2012/2/25 Michael Barton <Michael.Barton at asu.edu>:
>> On Feb 24, 2012, at 4:21 PM, Hamish wrote:
>>> Michael wrote:
>>>> I've just learned that typing "g.region" [return] from the terminal
>>>> does not launch the g.region GUI.
>>> worksforme, what happens for you? do you get an error message?
>> Nothing. No error message. Nothing happens
>>> how about "g.region --ui" ?
>> It brings up the GUI as it should--and as it should if you type g.region without arguments
>>> what does "g.gisenv get=GRASS_GUI" say?
>> wxpython (Note that other commands work as expected, although I have not tested all 300+)
>>> what about "echo $?" directly after running g.region from the command line?
>> It is the same as typing g.region help
>> Michael
>>> Hamish
>> _____________________
>> C. Michael Barton
>> Visiting Scientist, Integrated Science Program
>> National Center for Atmospheric Research &
>> University Corporation for Atmospheric Research
>> 303-497-2889 (voice)
>> Director, Center for Social Dynamics & Complexity
>> Professor of Anthropology, School of Human Evolution & Social Change
>> Arizona State University
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
C. Michael Barton
University Consortium for Atmospheric Research
