[GRASS-dev] why doesn't g.region launch gui?
Maris Nartiss maris.gis at gmail.com
Sat Feb 25 03:10:48 EST 2012
Hello Michael,
in GRASS 7 it's not a bug, it's a feature! [1]
If it's happening also in 6.4, then it's a result of backporting and
should be treated as a serious regression and thus should be fixed
ASAP.
Maris.
1. http://osgeo-org.1560.n6.nabble.com/wxGUI-new-packages-layout-tp3992790p3992803.html
2012/2/25 Michael Barton <Michael.Barton at asu.edu>:
> On Feb 24, 2012, at 4:21 PM, Hamish wrote:
>> Michael wrote:
>>> I've just learned that typing "g.region" [return] from the terminal
>>> does not launch the g.region GUI.
>> worksforme, what happens for you? do you get an error message?
> Nothing. No error message. Nothing happens
>> how about "g.region --ui" ?
> It brings up the GUI as it should--and as it should if you type g.region without arguments
>> what does "g.gisenv get=GRASS_GUI" say?
> wxpython (Note that other commands work as expected, although I have not tested all 300+)
>> what about "echo $?" directly after running g.region from the command line?
> It is the same as typing g.region help
> Michael
>> Hamish
> _____________________
> C. Michael Barton
> Visiting Scientist, Integrated Science Program
> National Center for Atmospheric Research &
> University Corporation for Atmospheric Research
> 303-497-2889 (voice)
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
