[GRASS-dev] [GRASS GIS] #1593: location wizard setting default extents broken
GRASS GIS trac at osgeo.org
Sun Feb 26 14:08:57 EST 2012
 Reporter:  cmbarton                         |       Owner:  grass-dev@…
     Type:  defect                           |      Status:  new
 Priority:  normal                           |   Milestone:  7.0.0
Component:  Default                          |     Version:  svn-trunk
 Keywords:  location wizard default extents  |    Platform:  Unspecified
      Cpu:  Unspecified                      |
 Trying to set default extents in the location wizard raises this error:
 2012-02-13 15:08:34.246 Python[15612:e0f] CFURLCreateWithString was passed
 this invalid URL string:
 '/System/Library/CoreServices/CommonCocoaPanels.bundle' (a file system
 path instead of an URL string). The URL created will not work with most
 file URL functions. CFURLCreateWithFileSystemPath or
 CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
   File
 "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/gis_set.py",
 line 388, in OnWizard
     grassdatabase = self.tgisdbase.GetValue())
   File
 "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/location_wizard/wizard.py",
 line 1806, in __init__
     defineRegion = RegionDef(self.parent, location = self.location)
   File
 "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/location_wizard/dialogs.py",
 line 102, in __init__
     key, val = line.split('=')
 ValueError: too many values to unpack
Ticket URL: <http://trac.osgeo.org/grass/ticket/1593>
