[GRASS-dev] grass toolboxes idea continued (g.extension)
Martin Landa landa.martin at gmail.com
Tue Jan 3 05:47:30 EST 2012
2012/1/3 Maris Nartiss <maris.gis at gmail.com>:
> I'm not in the mood to digg deeply into this concept. It looks similar
> to R packages, right? Can we borrow most of (design) from R to not
> reinvent the wheel and to learn from their mistakes/success?
we share just the idea, I don't know technical solution of providing R
packages so deeply. Anyway there is no so big overlap from my POV
(speaking about technical solution).
> Also, if we have an option to start a new, why limit ourselves to
> single or double letter as toolbox prefix? I assume, all modules in a
> toolbox should have a common prefix, like hy.flow, right?
Not at all, toolbox should be just set of modules, see initial example
for "Hydrology" toolbox. Toolbox is described in XML file [1] which
currently contains name, code, correlate toolboxes and list of
modules, eg.
Hydrology (HY)
* r.stream.basins
* r.stream.channel
* r.stream.distance
* r.stream.extract
* r.stream.order
* r.stream.segment
* r.stream.slope
* r.stream.snap
* r.stream.stats
Currently it means that if you run
g.extension -t ext=HY
it will install all r.stream modules from addons a register them in
GRASS_ADDON_BASE/modules.xml and GRASS_ADDON_BASE/toolboxes.xml. It's
already implemented. What should be done
* g.extension should modify wxGUI menu to add new items for each module
* g.extension should register new toolbar related to the given toolbox.
Any kind of help is very welcomed. Personally I have very limited time
for these tasks.
Martin
[1] https://svn.osgeo.org/grass/grass-addons/grass7/toolboxes.xml
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
