[GRASS-dev] Re: [GRASS GIS] #580: WinGRASS:
$GISBASE/etc/gui/scripts/ require something like $(EXE) to run
trac at osgeo.org
Fri Jan 6 07:54:42 EST 2012
#580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment(by martinl):
Replying to [comment:34 mmetz]:
> Reopening the ticket because calling python scripts from /scripts with
wxGUI does not work with the error message that the system does not know
what to do with py files. This applies to systems without a separate
system-wide python 2.x installation. Or is a separate python 2.x
installation now a requirement?
> Example: Settings -> Install extensions from add-ons fails.
This should be fixed in trunk. Probably we could introduce bat-files for
python scripts as in G6 for bash-scripts. I tried `bin\g.manual.bat`
@"%GRASS_PYTHON%" "%GISBASE%/scripts/g.manual.py" %*
from CLI
g.manual
command not found
g.manual.bat
line 1: @%GRASS_PYTHON%: command not found
Any idea?
Ticket URL: <http://trac.osgeo.org/grass/ticket/580#comment:35>
