[GRASS-dev] Re: [GRASS GIS] #580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
GRASS GIS trac at osgeo.org
Fri Jan 6 09:03:53 EST 2012
  Reporter:  hamish        |       Owner:  grass-dev@…
      Type:  defect        |      Status:  reopened
  Priority:  blocker       |   Milestone:  7.0.0
 Component:  wxGUI         |     Version:  svn-trunk
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment(by hellik):
 Replying to [comment:35 martinl]:
 > Replying to [comment:34 mmetz]:
 > > Reopening the ticket because calling python scripts from /scripts with
 wxGUI does not work with the error message that the system does not know
 what to do with py files. This applies to systems without a separate
 system-wide python 2.x installation. Or is a separate python 2.x
 installation now a requirement?
 > > Example: Settings -> Install extensions from add-ons fails.
 > This should be fixed in trunk. Probably we could introduce bat-files for
 python scripts as in G6 for bash-scripts. I tried `bin\g.manual.bat`
 > @"%GRASS_PYTHON%" "%GISBASE%/scripts/g.manual.py" %*
 > from CLI
 > g.manual
 > command not found
 > g.manual.bat
 > line 1: @%GRASS_PYTHON%: command not found
 > Any idea?
 I've tried some time ago
  g.manual.py.bat,
 as the bat-filename, it worked.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/580#comment:36>
