[GRASS-dev] GRASS 6.4.2RC3 : Launch script
Helena Mitasova
hmitaso at ncsu.edu
Mon Jan 16 19:34:27 EST 2012
further testing:
when I try Launch script,
I get the associated wxgui open, the command is correctly generated
but when I hit run I get the following error:
Launching script '/Users/helena/grassaddons_test/scripts/v.transectsold.py'...
[Errno 2] No such file or directory
the path in the error message is the correct path, but it looks like it is not being launched from there.
It is possible that I don't have GRASS6.4.2 installed as expected,
Michael, does r.landevol.py launch correctly through wxGUI for you?
Also g.extension does not quite work for me but it may be similar problem
(it installs the add-on correctly but gets error when I try to run it).
Thank you.
Helena
On Jan 12, 2012, at 1:40 PM, Martin Landa wrote:
> 2012/1/12 Markus Neteler <neteler at osgeo.org>:
>> A third and final release candidate of GRASS 6.4.2 is now available.
> 6.4.2RC3 also available in OSGeo4W framework, testing welcomed.
> http://trac.osgeo.org/osgeo4w/wiki/pkg-grass
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
