[GRASS-dev] v.info: projection info wrong
Martin Landa
landa.martin at gmail.com
Sat Jan 21 13:53:01 EST 2012
2012/1/21 Markus Metz <markus.metz.giswork at googlemail.com>:
> Yes, because "Vect_get_proj_name() and _zone() are typically unset?!"
> (see above). This (Vect_[get|set]_proj_name()) is weird because a
> vector's projection can hardly be different from the location's
> projection, and Vect_set_proj_name() has no effect. I would suggest to
> replace the corresponding parts in v.info with
> G_database_projection_name() and G_zone(), as used in r.info.
seems to be reasonable suggestion. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
