[GRASS-dev] v.info: projection info wrong
Markus Neteler
neteler at osgeo.org
Sat Jan 21 14:52:17 EST 2012
On Sat, Jan 21, 2012 at 7:53 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2012/1/21 Markus Metz <markus.metz.giswork at googlemail.com>:
>> Yes, because "Vect_get_proj_name() and _zone() are typically unset?!"
>> (see above). This (Vect_[get|set]_proj_name()) is weird because a
>> vector's projection can hardly be different from the location's
>> projection, and Vect_set_proj_name() has no effect. I would suggest to
>> replace the corresponding parts in v.info with
>> G_database_projection_name() and G_zone(), as used in r.info.
> seems to be reasonable suggestion. Martin
Sounds good also for me.
Interestingly I found another map:
GRASS 6.4.2svn (utm33_etna_mini):~/grass64/vector/v.info > v.info basins_10k
| Layer: basins_10k |
| Mapset: landsat |
| Database: /home/neteler/grassdata |
| Projection: Universal Transverse Mercator (zone 0) |
| N: 4223250 S: 4132440 |
| E: 531540 W: 444600 |
--> this map is a r.watershed generated map while the upper one was
imported with v.in.ogr.
After r50367 it is now:
| Projection: UTM (zone 33) |
Solved,
Markus
