[GRASS-dev] v.info: projection info wrong
Martin Landa landa.martin at gmail.com
Sun Jan 22 14:26:38 EST 2012
2012/1/21 Markus Metz <markus.metz.giswork at googlemail.com>:
> Yes, because "Vect_get_proj_name() and _zone() are typically unset?!"
it should be set [1] by Vect__open_old(). Probably when creating
vector map this information should be stored in head file? And then
checked when opening vector map if it's same with location projection
settings?
Martin
[1] http://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/open.c#L249
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
