[GRASS-dev] Re: [GRASS GIS] #1535: winGRASS g.extension.py problems
    trac at osgeo.org
    Wed Jan 25 10:12:20 EST 2012
 Reporter:  neteler                |       Owner:  martinl
     Type:  defect                 |      Status:  assigned
 Priority:  normal                 |   Milestone:  6.4.2
Component:  wxGUI                  |     Version:  6.4.2 RCs
 Keywords:  g.extension, wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32                 |
Comment(by martinl):
 Replying to [comment:5 neteler]:
 > I tried with the today's winGRASS6.4.svn:
 > g.extension.py extension=r.unpack svnurl=http://svn.osgeo.org/grass
 /grass-addons/grass6
 > Extension <r.unpack> already installed. Re-installing...
 > Downloading precompiled GRASS Addons <r.unpack>...
 > ERROR: GRASS Addons <r.unpack> not found
 > (Tue Jan 24 23:53:57 2012) Comando terminato (3 sec)
 Probably some problem with precompiled Addons binaries. Tested with the
 last build (1), seems to work. Could you test it again?
 (1)
 http://wingrass.fsv.cvut.cz/grass64/WinGRASS-6.4.SVN-r50440-1-Setup.exe
Ticket URL: <http://trac.osgeo.org/grass/ticket/1535#comment:7>
