[GRASS-dev] Re: [GRASS GIS] #1276: r.null after v.to.rast in
winGRASS does not
work properly (was: r.null in winGRASS does not work properly)
trac at osgeo.org
Fri Jan 27 16:14:27 EST 2012
#1276: r.null after v.to.rast in winGRASS does not work properly
Reporter: helena | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: 6.4.1 RCs
Keywords: r.null, v.to.rast, wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Changes (by hamish):
* keywords: r.null, wingrass => r.null, v.to.rast, wingrass
Comment:
Replying to [comment:17 glynn]:
> Er, what?
just that the warning messages need to be better targeted so that they
only print in cases when they are meaningful. (and don't try to remove() a
file which doesn't exist, etc)
> So this is specifically about running r.null on a map created by a
vector module?
> Does r.null work correctly on maps not created by vector modules? If so,
the
> title should be updated to reflect that.
The failing r.null is the symptom, I would guess that `g.remove rast` for
that map would also fail (untested) as the zombie v.to.rast process would
still have the cell file open.
> In that case, the problem is one of the DBMI driver failing to terminate
along
> with its parent. I note that `db__recv_procnum()` only returns DB_EOF if
> `db__recv()` returns 0 (indicating EOF). If it returns an error, it will
return
> DB_OK. Try r50496.
is r50497 "SF_CLOSE_DESCRIPTOR should actually close the descriptor"
related? should it be backported?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:18>
