[GRASS-dev] Re: [GRASS GIS] #1276: r.null after v.to.rast in winGRASS does not work properly
GRASS GIS trac at osgeo.org
Fri Jan 27 18:57:23 EST 2012
 Reporter:  helena                       |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  critical                     |   Milestone:  6.4.2
Component:  Raster                       |     Version:  6.4.1 RCs
 Keywords:  r.null, v.to.rast, wingrass  |    Platform:  MSWindows 7
      Cpu:  Unspecified                  |
Comment(by hamish):
 Replying to [comment:17 glynn]:
 > In that case, the problem is one of the DBMI driver failing to terminate
 along
 > with its parent. I note that db__recv_procnum() only returns DB_EOF if
 db__recv()
 > returns 0 (indicating EOF). If it returns an error, it will return
 DB_OK. Try r50496.
 r50496 causes a `dbmi: Protocol error`, e.g. with `v.info -c mapname`.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:19>
