[GRASS-dev] Re: [GRASS GIS] #1519: Opening a saved workspace doesn't display all layers correctly in 6.4.2RC2
GRASS GIS trac at osgeo.org
Sat Jan 28 00:43:12 EST 2012
 Reporter:  shanel  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  minor   |   Milestone:  6.4.2
Component:  wxGUI   |     Version:  6.4.2 RCs
 Keywords:          |    Platform:  Linux
      Cpu:  x86-64  |
Comment(by shanel):
 Have just tried in svn version 50505 on 28 Jan 2012; still find bug.
 Repeated it using North Carolina dataset by following steps:
 1. open GRASS in NC/Permanent
 2. add raster > soilsID
 3. add vector > busroute1
 4. add vector > zipcodes_wake
 #optionally adjust line/fill colours e.g. for zipcodes, don't display area
 so raster is visible
 5. save this as a workspace
 6. close GRASS/workspace, open it from the saved file
  > it seems to show busroute, then zipcode bdy and soils flash up, then
 display finishes with only soilsID raster visible.
 7. uncheck top item in Display manager i.e. zipcodes vector
  > display then refreshes and shows busroute vector over soils raster.
 8. checking zipcodes again displays all three layers.
 output from terminal when I open the saved workspace (debug=5 output)
 attached as a file for reference.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1519#comment:2>
