[GRASS-dev] patch for grass_trunk d.vect.thematic
Patrice Dumas pertusus at free.fr
Mon Jan 30 17:10:48 EST 2012
Hello,
A little patch for d.vect.thematic.py in trunk.  It shows up if you use
  d.vect.thematic themetype=graduated_points
It fixes 2 things.  An unquoted string "graduated_lines".  f_psmap not
being initialized although it is used line 1049.  I moved the f_psmap
initialization before.
Pat
Index: scripts/d.vect.thematic/d.vect.thematic.py
--- scripts/d.vect.thematic/d.vect.thematic.py	(r?vision 50573)
+++ scripts/d.vect.thematic/d.vect.thematic.py	(copie de travail)
@@ -427,6 +427,7 @@
     # graduated color thematic mapping
+    f_psmap = file(tmp_psmap, 'w')
     if themetype == "graduated_colors":
         if colorscheme in colorschemes:
             startc, endc = colorschemes[colorscheme]
@@ -728,7 +729,6 @@
                               where = sqlwhere,
                               color = linecolor, fcolor = themecolor, icon = icon, size = ptsize)
-            f_psmap = file(tmp_psmap, 'w')
             if type in ["line", "boundary"]:
                 out(f_psmap, locals(), """\
 vlines $map
@@ -914,7 +914,7 @@
                 lineht = 4
             if i < xlower or i >= xupper:
-                if themetype == graduated_lines:
+                if themetype == "graduated_lines":
                     out(f_graph, locals(), """\
 color $linecolor
