[GRASS-dev] patch for grass_trunk d.vect.thematic
    Moritz Lennert
    mlennert at club.worldonline.be
    Tue Jan 31 05:24:16 EST 2012
On 30/01/12 23:10, Patrice Dumas wrote:
> Hello,
> A little patch for d.vect.thematic.py in trunk.  It shows up if you use
>    d.vect.thematic themetype=graduated_points
> It fixes 2 things.  An unquoted string "graduated_lines".  f_psmap not
> being initialized although it is used line 1049.  I moved the f_psmap
> initialization before.
Thanks, I'll apply it in SVN.
Moritz
