[GRASS-dev] patch for grass_trunk d.vect.thematic
Moritz Lennert
mlennert at club.worldonline.be
Tue Jan 31 05:36:51 EST 2012
On 31/01/12 11:24, Moritz Lennert wrote:
> On 30/01/12 23:10, Patrice Dumas wrote:
>> Hello,
>> A little patch for d.vect.thematic.py in trunk. It shows up if you use
>> d.vect.thematic themetype=graduated_points
>> It fixes 2 things. An unquoted string "graduated_lines". f_psmap not
>> being initialized although it is used line 1049. I moved the f_psmap
>> initialization before.
> Thanks, I'll apply it in SVN.
Done.
Moritz
