[GRASS-dev] patch for grass_trunk d.vect.thematic
Patrice Dumas
pertusus at free.fr
Tue Jan 31 05:54:57 EST 2012
On Tue, Jan 31, 2012 at 11:36:51AM +0100, Moritz Lennert wrote:
> On 31/01/12 11:24, Moritz Lennert wrote:
> >On 30/01/12 23:10, Patrice Dumas wrote:
> >>Hello,
> >>A little patch for d.vect.thematic.py in trunk. It shows up if you use
> >>d.vect.thematic themetype=graduated_points
> >>It fixes 2 things. An unquoted string "graduated_lines". f_psmap not
> >>being initialized although it is used line 1049. I moved the f_psmap
> >>initialization before.
> >Thanks, I'll apply it in SVN.
> Done.
Thanks !
Pat
