[GRASS-dev] [GRASS GIS] #1683: error message v.add.col on MacOSX
trac at osgeo.org
Wed Jul 4 03:23:57 PDT 2012
Reporter: jradinger | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Shell Scripts | Version: svn-develbranch6
Keywords: v.db.addcol | Platform: All
Cpu: Unspecified |
Changes (by hamish):
* keywords: v.add.col => v.db.addcol
* component: Database => Shell Scripts
Comment:
The immediate culprit is `eval g.gisenv`,
The underlying fix is to not store the addon path as a GRASS variable,
store it as a shell environment variable -- and only a shell variable --
instead.
Remove it from the g.gisenv list with:
g.gisenv set="ADDON_PATH="
then v.db.addcol should be happy.
Trying to make it both a shell environment variable and a grass variable
is well intentioned, but blurring definitions so that things can be set
and read independently in multiple places using the same namespace is
ultimately going to create more problems than it solves. The main question
I think is if we need some other place besides .grass.bashrc to store this
sort of thing, to be sourced by the grass startup script. ? (currently for
grass6 it needs to be set in ~/.bashrc since .grass.bashrc is sourced
later in the startup script.
The GUI can modify its own running environment on the fly with
os.environ(); command line users who want to modify their environment
generally can, and indeed want to, take care of themselves.
cheers,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:5>
