[GRASS-dev] [GRASS GIS] #1683: error message v.add.col on MacOSX
GRASS GIS trac at osgeo.org
Wed Jul 4 03:35:51 PDT 2012
 Reporter:  jradinger      |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  major          |   Milestone:  6.4.3
Component:  Shell Scripts  |     Version:  svn-develbranch6
 Keywords:  v.db.addcol    |    Platform:  All
      Cpu:  Unspecified    |
Comment(by hamish):
 n.b. the `eval g.gisenv` will still be problematic if the GISDBASE path
 contains a space. In this case just the MAPSET name is needed, so `eval
 g.gisenv MAPSET` avoids trouble, but quoting by g.gisenv is something we
 should probably discuss.
 (nonetheless, having GRASS_ADDON_PATH enviro var and ADDON_PATH grass var
 is unfortunate)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:6>
