[GRASS-dev] GRASS trac system, join user login
Martin Landa
landa.martin at gmail.com
Thu Jul 5 01:14:28 PDT 2012
2012/7/5 Johannes Radinger <JRadinger at gmx.at>:
> Thank you! Now all tickets are assign to jradinger. I tried to trace the
> problem and found out that the login is not case sensitive (I can log in with both names) but the tickets are assigned only to the name used for login. That is strange as there is only one user ID. I am using Safari (on MacOSX) as a browser for http://trac.osgeo.org/grass/wiki.
probably should be reported as ticket [1] (Component: System Admin)?
Martin
[1] https://trac.osgeo.org/osgeo
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
